Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-17-2013, 11:45 PM   #1
Replacing windows
Is it necessary to completely remove vinyl siding when replacing windows?
craig o is offline   Reply With Quote
Old 01-18-2013, 10:00 AM   #2
Windows & Dogs
Taylor Rae's Avatar
Replacing windows
Not for pocket replacement windows. But if you are doing a full-frame replacement (or new construction) then you should remove the siding around it to be able to do a proper installation. The vinyl siding can also be cut but then you need to get creative about flashing.
Taylor Rae is offline   Reply With Quote
Old 01-18-2013, 10:06 AM   #3
Replacing windows
That's the key, replacement or new constrution?
Old 01-18-2013, 10:48 AM   #4
Replacing windows
Thanks guys. Replacing entire windows, including frames. Old ones are metal frames installed around 1988, will probably install vinyl framed new windows
Old 01-18-2013, 11:08 AM   #5
Replacing windows
Then the siding will need to come off to do it right.
Your going to need a zipper tool, flat bar, some window tape, shims, snips or a plywood blade on backwards on a ciruler saw, caulking, piece of under sill (also called utility trim).
Do yourself a favor and make sure to buy windows with a nailing fin and a built in J moulding. Far less work to install, and less chance for a leak.
http://www.bing.com/images/search?q=...3C11A5&first=1
Make sure when cutting the siding to leave room for it to expand or it's going to buckle when it gets warmer.
Old 01-18-2013, 11:22 AM   #6
Replacing windows
Thanks man.
Old 01-18-2013, 11:50 AM   #7
Windows & Remodeling
HomeSealed's Avatar
Replacing windows
First, if you have trim around your existing windows, only that will need to be removed in most cases, no siding. Secondly, even if the siding comes directly against the existing window (meaning that the nailing flange is behind it) there are two methods: 1) Cut the siding back and then add trim over the new nailing flange (no siding removal necessary). This is fairly common. 2) Remove the siding around every window in order to remove and reinstall the new window. This is far less common unless you are replacing siding, as the majority of the siding on the home will need to be removed if you are replacing all of the windows. There are third and fourth options in an "express install" (Nail fin on existing window is cut, new window has no fin, retrofit a drip cap), and a "frame jump" (depending on the orientation of the existing aluminum frames). Those two options are less desirable however as they offer fewer layers of protection, and must be executed to a high level of detail to function and seal properly.
My advice for DIY, would be option one or two. I'd also encourage you to look up "how to" material, both videos and printed instructions so that you are able to flash every opening properly. This is absolutely critical... If you search this forum, you should actually find some links for that.
HomeSealed is offline   Reply With Quote
Old 01-18-2013, 11:58 AM   #8
Replacing windows
Thank you
Old 01-18-2013, 12:04 PM   #9
Replacing windows
A picture of the outside of the windows you have now would be a big help.
HomeSealed (01-18-2013)
Pella Windows - Serious Frost Issue snowman72 General Discussion 22 07-08-2011 01:39 AM
Replacing windows - masonry construction katit Remodeling 4 05-18-2010 01:52 PM
Replacing Windows (Which Brand?) dixieman Remodeling 3 04-30-2009 07:45 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 01:44 PM
