-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Replacing windows (http://www.diychatroom.com/f104/replacing-windows-169423/)
craig o 01-17-2013 11:45 PM
Replacing windows
Is it necessary to completely remove vinyl siding when replacing windows?
Taylor Rae 01-18-2013 10:00 AM
Not for pocket replacement windows. But if you are doing a full-frame replacement (or new construction) then you should remove the siding around it to be able to do a proper installation. The vinyl siding can also be cut but then you need to get creative about flashing.
joecaption 01-18-2013 10:06 AM
That's the key, replacement or new constrution?
craig o 01-18-2013 10:48 AM
Thanks guys. Replacing entire windows, including frames. Old ones are metal frames installed around 1988, will probably install vinyl framed new windows
joecaption 01-18-2013 11:08 AM
Then the siding will need to come off to do it right.
Your going to need a zipper tool, flat bar, some window tape, shims, snips or a plywood blade on backwards on a ciruler saw, caulking, piece of under sill (also called utility trim).
Do yourself a favor and make sure to buy windows with a nailing fin and a built in J moulding. Far less work to install, and less chance for a leak.
http://www.bing.com/images/search?q=...3C11A5&first=1
Make sure when cutting the siding to leave room for it to expand or it's going to buckle when it gets warmer.
craig o 01-18-2013 11:22 AM
Thanks man.
HomeSealed 01-18-2013 11:50 AM
First, if you have trim around your existing windows, only that will need to be removed in most cases, no siding. Secondly, even if the siding comes directly against the existing window (meaning that the nailing flange is behind it) there are two methods: 1) Cut the siding back and then add trim over the new nailing flange (no siding removal necessary). This is fairly common. 2) Remove the siding around every window in order to remove and reinstall the new window. This is far less common unless you are replacing siding, as the majority of the siding on the home will need to be removed if you are replacing all of the windows. There are third and fourth options in an "express install" (Nail fin on existing window is cut, new window has no fin, retrofit a drip cap), and a "frame jump" (depending on the orientation of the existing aluminum frames). Those two options are less desirable however as they offer fewer layers of protection, and must be executed to a high level of detail to function and seal properly.
My advice for DIY, would be option one or two. I'd also encourage you to look up "how to" material, both videos and printed instructions so that you are able to flash every opening properly. This is absolutely critical... If you search this forum, you should actually find some links for that.
craig o 01-18-2013 11:58 AM
Thank you
joecaption 01-18-2013 12:04 PM
A picture of the outside of the windows you have now would be a big help.
