Replacing Window Glass - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 10:59 PM   #1
Replacing window glass
I have a double pane glass window that was shot twice with a BB gun. The top and bottom sections both were shot once but the first panes were only thing damaged. My question is, can I replace just the glass or do I have to have whole window replaced. Can I do it myself or should I have someone else do it? I am a pretty handy go around the house.
Thank for any responses.
Donald-64 is offline   Reply With Quote
Old 04-23-2012, 11:02 PM   #2
Rewards Points: 12,856
If it's a welded seam vinyl window, then no your going to need two new sashes.
Old 04-23-2012, 11:08 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
that may indeed be the better option, however there is no window that does not have glazing beads on one side (interior or exterior), facilitating IG replacement. Glass replacement will be cheaper in material, but sash replacement often makes up for that (and more) in labor.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-24-2012, 12:09 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
How old is the window? Any serial number identification?
replacing insulated glass in picture unit - Simonton mf915 Windows and Doors 3 01-27-2012 10:30 AM
Glass block window in tiled shower stall ddmcc Windows and Doors 16 01-04-2012 11:48 PM
Replacing glass on a bay window RedHelix Windows and Doors 2 11-21-2011 01:24 PM
Replacing a window whattodo Remodeling 3 03-08-2010 07:51 AM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
