Replacing Weatherstripping On Marvin Wood Casement Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 09:52 AM   #1
Replacing weatherstripping on Marvin wood casement windows
I have "old" (1988) Marvin wood casement windows. The windows themselves are in good shape, but -- on most of them -- the weatherstripping on all 4 sides of the sash is crumbling and needs to be replaced. The original weatherstripping is anchored in a groove (kerf?), and is "easy" to remove. Does anyone have any experience replacing weatherstripping like this? (I'm even having trouble finding replacement weatherstripping. Even if I found, I don't see any way of putting it in the bottom and one of the sash sides without removing the sash itself. It seems to me that some sort of adhesive leaf or bubble weatherstripping would be easier to deal with...
Any and all suggestions are welcome. Thanks.
giger123 is offline   Reply With Quote
Old 05-08-2011, 09:58 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
pulling the sash on a casement window is easy and you should be
able to get the weather strip from Marvin
Tom Struble is offline   Reply With Quote
Old 05-08-2011, 07:08 PM   #3
Pulling sashes on this Marvin casement windows of this era is not "easy". That's part of the reason I asked for suggestions, by which I meant constructive ones, not condescending ones. I was hoping for an alternative solution.
Old 05-09-2011, 06:25 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Firstly, don't get defensive when a Pro, like Tom, tells you it's easy.
All sashes are installed into a frame and, therefore, can be removed.
We do this all the time ....it's easy.
Sticking on a retrofit piece of weatherstrip that was not meant for that application is not the correct way to do this. You asked.
You have Marvin Windows. They are a great window. Don't mess them up with a botched weatherstrip attempt.
I would go to a Marvin Store and get advice. You can ask your local lumberyard that sells Marvin to get you in contact with a local Rep. He can instruct, advise you and probably get you parts....if you ask politely.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Tom Struble (05-09-2011)
Old 05-09-2011, 06:43 AM   #5
wow
Old 05-09-2011, 06:50 AM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Originally Posted by tomstruble View Post
wow
I know...
Tags
casement window , kerf , replace , weatherstripping
Replacing wood siding with vinyl jbjones Building & Construction 33 05-02-2011 12:23 AM
replacing aging wood and chain link tns1 Building & Construction 2 12-16-2009 09:45 AM
Replacement Windows - Pella, Anderson, Marvin? The what to do about blinds? ms_obvious General DIY Discussions 3 11-29-2009 08:16 AM
Replacing 100 yr old windows Minden General DIY Discussions 3 07-11-2006 11:58 AM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
