Replacing Standard Sliding Glass Door With Same Size Fixed On Side Hinged Second Side - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 10:44 AM   #1
Replacing standard sliding glass door with same size fixed on side hinged second side
I have a completely worn out sliding glass door with aluminum tracks in bad shape. I have a same size door to fit opening, with one side fixed, the other hinged. What will i need to do to make this happen? Do I need to replace the frame?
Jacey is offline   Reply With Quote
Old 12-07-2011, 10:58 AM   #2
Rewards Points: 14,306
Does the new door have nailing fins on the sides and top, or brick molding?
In most cases the casing trim, whole door and frame has to come out and the new door just fits in it's place, but if there's nailing fins the siding and J moulding (if you have vinyl siding) have to come off in that area, caulking gets put where the nailing fins are going to sit, the door gets nailed in place once you check for plumb, window tape gets installed over the nailing fins. And siding reinstalled. Fill the gap between the jams and rough framing with fiberglass or low expanding foam and reinstall the casing.
You also would be far better off buy a sill pan for the door to sit in so water can not get in and take out the subflooring.
Do a key word search on "jam sill".
Old 12-08-2011, 06:13 AM   #3
Assuming the new door is prehung, just remove the old door/frame and insert the new in the opening. Of course there is more to than that, but there should be directions with the door.
Proper flashing around the door and the threshold are VERY important.
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General DIY Discussions 12 05-02-2013 10:39 AM
Replacing a sliding glass door question cdm Carpentry 45 04-11-2011 04:12 PM
Replacing a sliding glass door with a new window twildey Building & Construction 1 07-22-2010 08:40 AM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 05:01 AM
Replacing header over sliding glass doors bluefitness Remodeling 11 11-04-2008 08:04 PM
