Replacing Special Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 07:12 PM   #1
Rewards Points: 350
So bear with me, because I have to make up the lingo as I go, being an amateur and all...
Attached is a pic of a window I need replaced. I got one quote so far, and it floored me (almost $4,000). I expected it to be expensive, the two bottom windows swing out using crank handles, and that top half moon is just stationary. The treatment on the top half I could live without!
So I am looking for more quotes, but also talked to someone at a local window shop, and he said it is a DIYer project, although an advanced one. My question would be, how is that half moon framed in? Or is the window sold as a complete rectangle, and the half moon sits in a boxed in sort of frame (if that makes any sense at all).
Thank you for reading.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 09-05-2013, 07:19 PM   #2
DIY staff
Rewards Points: 7,174
That is a double casement window with a half round on top---
Any window supplier can make that up for you---you have one thing good going there---the wide exterior trim will allow the use of a flanged,new construction window---
Old 09-05-2013, 07:30 PM   #3
Rewards Points: 13,994
Why would you need to know how it's framed?
Just buy a new window the same size.
Old 09-05-2013, 07:55 PM   #4
Rewards Points: 350
Currently it's wood, would like to make the jump to vinyl.
Do you think taking this one out and putting a new one in is a DIY job requiring moderate skill? My only gripe is the window is up quite high, I would probably put some roof jacks on the roof below the window so I could easily have access to it. I would try to do most of the job inside the house of course!
Old 09-05-2013, 08:24 PM   #5
DIY staff
This might or might not be a DIY job---
The demo is one man on a ladder for a couple of hours---
the install--three men would be my choice--I would remove the sashes on the bottom and have two guys install it from the inside---passing it out of the empty opening--and a third man outside with a level and a screw gun.
If it is a wood cored window--I install temporary handles on the inside--
I've put in some huge windows this way---sashes need to be reinstalled before the thing is screwed off completely to make sure the frame is still square.
Basement window worth replacing? bryanp22 Windows and Doors 10 03-31-2013 04:28 PM
Replacing an in-shower window Beaker0917 Kitchen & Bath Remodeling 7 01-01-2013 01:16 PM
Replacing exterior door with window plus wall in brick opening mje113 Remodeling 2 11-07-2012 02:16 PM
replacing a window with french doors monicalyn Building & Construction 5 09-12-2011 01:36 PM
Replacing a window w/ door - siding question CoconutPete Remodeling 12 08-02-2011 02:41 PM
