-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Replacing Special Window (http://www.diychatroom.com/f104/replacing-special-window-186552/)
dougp23 09-05-2013 07:12 PM
1 Attachment(s)
So bear with me, because I have to make up the lingo as I go, being an amateur and all...
Attached is a pic of a window I need replaced. I got one quote so far, and it floored me (almost $4,000). I expected it to be expensive, the two bottom windows swing out using crank handles, and that top half moon is just stationary. The treatment on the top half I could live without!
So I am looking for more quotes, but also talked to someone at a local window shop, and he said it is a DIYer project, although an advanced one. My question would be, how is that half moon framed in? Or is the window sold as a complete rectangle, and the half moon sits in a boxed in sort of frame (if that makes any sense at all).
Thank you for reading.
oh'mike 09-05-2013 07:19 PM
That is a double casement window with a half round on top---
Any window supplier can make that up for you---you have one thing good going there---the wide exterior trim will allow the use of a flanged,new construction window---
joecaption 09-05-2013 07:30 PM
Why would you need to know how it's framed?
Just buy a new window the same size.
dougp23 09-05-2013 07:55 PM
Currently it's wood, would like to make the jump to vinyl.
Do you think taking this one out and putting a new one in is a DIY job requiring moderate skill? My only gripe is the window is up quite high, I would probably put some roof jacks on the roof below the window so I could easily have access to it. I would try to do most of the job inside the house of course!
oh'mike 09-05-2013 08:24 PM
This might or might not be a DIY job---
The demo is one man on a ladder for a couple of hours---
the install--three men would be my choice--I would remove the sashes on the bottom and have two guys install it from the inside---passing it out of the empty opening--and a third man outside with a level and a screw gun.
If it is a wood cored window--I install temporary handles on the inside--
I've put in some huge windows this way---sashes need to be reinstalled before the thing is screwed off completely to make sure the frame is still square.
