Replacing Slider Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 05:29 PM   #1
Hello,
I have a home built in the 60's with the original wood slider windows. They are extremely drafty and need to be replaced. The exterior has been updated with vinyl siding and I want to replace the old sliders with new construction double hung windows. Some of the sliders are fairly large (64" x 44" -/+) so I plan on getting twin double hung. How should I go about installing the new construction windows? Pull the siding back?
skaboot is offline   Reply With Quote
Old 12-18-2011, 06:33 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Why didn't you replace the windows first?
Yes, the siding needs to come back off.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-18-2011, 08:09 PM   #3
Registered User
Rewards Points: 526
You may have enough J-channel for the new windows, may not....
Building paper water-resistive barrier; http://www.buildingscience.com/docum...researchreport
Don’t just stuff some fiberglass insulation next to them on the inside, use non-expanding canned foam. Buy a "zip" tool for siding removal. Help with install/removal; http://www.abtco.com/kp_abtco/docs/A...tructions_.pdf
Use a sill pan and dam-end head flash for optimum results.
The WRB is critical: https://docs.google.com/viewer?a=v&q...WrZBbBZoIUXgxw
Gary
Old 12-18-2011, 09:43 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Siding is going to have to come off around the openings.
Google Flex Wrap and invest in the proper water management tools to make sure you don't have a future problem.
Old 12-21-2011, 08:04 PM   #5
The siding was updated before I bought the house...trust me it would have been done when the siding was replaced.
Old 12-21-2011, 08:06 PM   #6
Gary
Gary, thanks for the reply. I appreciate your help!
Old 12-21-2011, 08:07 PM   #7
Originally Posted by Windows on Wash
+1
Thanks for the reply.
Replacing Windows In Brick House huesmann Windows and Doors 5 09-26-2011 06:31 AM
Replacing weatherstripping on Marvin wood casement windows giger123 Windows and Doors 5 05-09-2011 06:50 AM
Replacing old aluminum windows cocean Building & Construction 2 01-13-2010 05:55 AM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
Replacing windows silverado692 General DIY Discussions 3 11-06-2004 09:42 PM
