-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Replacing Slider Windows (http://www.diychatroom.com/f104/replacing-slider-windows-126968/)
skaboot 12-18-2011 05:29 PM
Hello,
I have a home built in the 60's with the original wood slider windows. They are extremely drafty and need to be replaced. The exterior has been updated with vinyl siding and I want to replace the old sliders with new construction double hung windows. Some of the sliders are fairly large (64" x 44" -/+) so I plan on getting twin double hung. How should I go about installing the new construction windows? Pull the siding back?
titanoman 12-18-2011 06:33 PM
Why didn't you replace the windows first?
Yes, the siding needs to come back off.
Sent from a Samsung Galaxy S2
Gary in WA 12-18-2011 08:09 PM
You may have enough J-channel for the new windows, may not....
Building paper water-resistive barrier; http://www.buildingscience.com/docum...researchreport
Don’t just stuff some fiberglass insulation next to them on the inside, use non-expanding canned foam. Buy a "zip" tool for siding removal. Help with install/removal; http://www.abtco.com/kp_abtco/docs/A...tructions_.pdf
Use a sill pan and dam-end head flash for optimum results.
The WRB is critical: https://docs.google.com/viewer?a=v&q...WrZBbBZoIUXgxw
Gary
Windows on Wash 12-18-2011 09:43 PM
+1
Siding is going to have to come off around the openings.
Google Flex Wrap and invest in the proper water management tools to make sure you don't have a future problem.
skaboot 12-21-2011 08:04 PM
The siding was updated before I bought the house...trust me it would have been done when the siding was replaced.
skaboot 12-21-2011 08:06 PM
Gary
Gary, thanks for the reply. I appreciate your help!
skaboot 12-21-2011 08:07 PM
Originally Posted by Windows on Wash
+1
Thanks for the reply.
