Replacing Shower Window With Glass Block - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 03:22 PM   #1
Replacing shower window with Glass block
Hey folks
So I've got a fixer upper home that I'm currently reworking the bathroom of. The window faces to the front yard, and it's pretty obvious that glass block is the way to go. I'm going with the Pittsburgh-Corning pre-assembled vinyl-frame windows: (http://pittsburghcorning.com/files/p...ows_gb-277.pdf).
I'm thinking of going with the 40x40 size, and here's why: the measurements of the current window. I measured in three spots across the top and side.
Top measurements are: 43, 43.0625, 43
Side measurements are: 45.625, 45.625, 45.5
The product sheet indicates that 40.9375" are required for the rough opening size. That's an inch or two off on either side, on all sides. How can I compensate for this? Any good videos online of this type of window replacement (youtube etc?)
Thanks in advance.
Cm1384 is offline   Reply With Quote
Old 03-08-2011, 07:25 AM   #2
It is easy to make an opening smaller, but can be quite difficult to make it bigger. There are lots of ways to make it smaller, but the simplest and water proof way now, is to use PVC 'lumber'. It comes in stock wood sizes and once installed and caulked, is water and rot proof.
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 05:09 PM
Glass Block Window - Two Layers of Siding myowngc Building & Construction 1 12-23-2010 02:20 PM
glass block window Morjade Building & Construction 1 04-23-2009 07:32 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 06:24 PM
Shower in Window jchri66 Remodeling 1 05-27-2008 01:50 PM
