Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 06-27-2012, 09:58 PM   #1
replacing seal in double glass window?
I see condensation in my double-glass window. Someone had told me that the seal inside the window is degraded. Is there an instruction on removing the window glass and replace the seal? Can I bring the seal to HomeDepot to buy a replacement? Thanks for the help.
kel456 is offline   Reply With Quote
Old 06-27-2012, 10:28 PM   #2
Exterior Construction
Windows on Wash's Avatar
A picture of the window will help quite a bit.
You have several options:
  • Buy a replacement sash from the manufacturer if it is not under warranty (most expensive but easiest from point A to point B).
  • De-glaze the window and have the glass replaced by a glazing shop (Home Depot cannot handle that repair) and installed a new sealed IGU (insulated glass unit)
  • Have the IGU vented via breather holes and hope that this eliminates the condensation and keeps it from coming back.
Old 06-28-2012, 11:54 AM   #3
A picture of the window type. What do you think? Thanks.
Old 06-28-2012, 01:26 PM   #4
Double pane aluminum window.
Which sash is showing the condensation and does the top sash come down?
Old 06-28-2012, 03:32 PM   #5
The condensation is not in this window. I was in a hurry this morning to leave for work so I quickly toke a picture from a best possible sun light angle to show the window frame because I don’t know the my window type. The top sash does come down and both sashes can be removed. A few windows were serviced for the seal problem about 3 years ago. I guess it was poorly done. It was done very quickly in my apartment hallway. Even though I can get this done for no charge by my building management but I have to wait from at least 6 months to 1 year. If I learn how to do this then I can do the repair convenience if the task is not difficult. Since I have most of the tools that a home auto mechanic has, I think I maybe able to tackle this problem.
Old 06-29-2012, 08:01 AM   #6
If you can get the size of the glass pack, you should be able to disassemble the sash and swap out the glass if you have the glass pack pre-made.
Old 06-29-2012, 10:09 AM   #7
If the term glass pack means the actual entire double glass piece then I don't the glass pre-made. If changing the entire glass piece then I think I got rip off when my windows were worked on because I did not see the 2 fellows take any old glass piece with them. Is that how it is done changing the glass pack (entire double glass piece)?
Old 06-29-2012, 10:22 AM   #8
They probably swapped out the sashes which is easiest and most painless.
Old 06-29-2012, 10:31 AM   #9
I agree with windows, no way they "fix it" out in the hallway.
Old 06-29-2012, 10:37 AM   #10
Is it a difficult task to remove the glass pack and clean out the stain and seal it with say silicon?
Old 06-29-2012, 10:47 AM   #11
why not contact the manufacturer of the window and see if they have a replacement glass package or a new sash that inculdes the glass package.
hammerlane is offline   Reply With Quote
Glass Block Window - Two Layers of Siding myowngc Building & Construction 1 12-23-2010 02:20 PM
window performance question renbelle Building & Construction 4 10-06-2010 03:25 PM
how to replace old window glass to double framed glass dubaimap Building & Construction 5 06-26-2009 04:02 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 06:24 PM
