-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   replacing seal in double glass window? (http://www.diychatroom.com/f104/replacing-seal-double-glass-window-148461/)
kel456 06-27-2012 09:58 PM
I see condensation in my double-glass window. Someone had told me that the seal inside the window is degraded. Is there an instruction on removing the window glass and replace the seal? Can I bring the seal to HomeDepot to buy a replacement? Thanks for the help.
Windows on Wash 06-27-2012 10:28 PM
A picture of the window will help quite a bit.
You have several options:
  • Buy a replacement sash from the manufacturer if it is not under warranty (most expensive but easiest from point A to point B).
  • De-glaze the window and have the glass replaced by a glazing shop (Home Depot cannot handle that repair) and installed a new sealed IGU (insulated glass unit)
  • Have the IGU vented via breather holes and hope that this eliminates the condensation and keeps it from coming back.
kel456 06-28-2012 11:54 AM
A picture of the window type. What do you think? Thanks.
Windows on Wash 06-28-2012 01:26 PM
Double pane aluminum window.
Which sash is showing the condensation and does the top sash come down?
kel456 06-28-2012 03:32 PM
The condensation is not in this window. I was in a hurry this morning to leave for work so I quickly toke a picture from a best possible sun light angle to show the window frame because I donít know the my window type. The top sash does come down and both sashes can be removed. A few windows were serviced for the seal problem about 3 years ago. I guess it was poorly done. It was done very quickly in my apartment hallway. Even though I can get this done for no charge by my building management but I have to wait from at least 6 months to 1 year. If I learn how to do this then I can do the repair convenience if the task is not difficult. Since I have most of the tools that a home auto mechanic has, I think I maybe able to tackle this problem.
Windows on Wash 06-29-2012 08:01 AM
If you can get the size of the glass pack, you should be able to disassemble the sash and swap out the glass if you have the glass pack pre-made.
kel456 06-29-2012 10:09 AM
If the term glass pack means the actual entire double glass piece then I don't the glass pre-made. If changing the entire glass piece then I think I got rip off when my windows were worked on because I did not see the 2 fellows take any old glass piece with them. Is that how it is done changing the glass pack (entire double glass piece)?
Windows on Wash 06-29-2012 10:22 AM
They probably swapped out the sashes which is easiest and most painless.
joecaption 06-29-2012 10:31 AM
I agree with windows, no way they "fix it" out in the hallway.
kel456 06-29-2012 10:37 AM
Is it a difficult task to remove the glass pack and clean out the stain and seal it with say silicon?
hammerlane 06-29-2012 10:47 AM
why not contact the manufacturer of the window and see if they have a replacement glass package or a new sash that inculdes the glass package.
