Replacing A Pane - Garden Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 11:20 PM   #1
Rewards Points: 45
replacing a pane - garden window
Trying to buy a house and would like to know -
can it be done and how difficult is it to replace a pane in a garden window.
At the time I saw it I thought it should be easy, but on second, third and fourth thoughts, maybe not...
the cracked pane is the right side pane.
To make things even worse, I don't remember if it is single or dual pane - any help, comments would be helpful.
hopefully, it is easy rather than have to replace the whole unit... but let me have the news...
thanks,
Jeff
jeffeg is offline   Reply With Quote
Old 09-02-2012, 12:04 AM   #2
Too Short? Cut it Again!
So long as you can pull the window apart it should be no big deal. The pane should be held in place by something like glazing clips on the inside. Pull those and the glass should come out. You may have to remove some glazing putty on the outside too. Take the pane to a glass shop and have either a single pane or a double one cut for you if that is what it turns out to be. Glaze it in place and reassemble the frame.
Old 09-02-2012, 12:43 AM   #3
Rewards Points: 45
makes sense
to be able to replace a pane instead of the whole unit, but sometimes manufacturers don't make sense.
thanks for the help, I appreciate it.
Sources for kitchen garden window? Eric in NC General DIY Discussions 11 06-06-2014 10:03 PM
Help Replacing Window Pane rosco Carpentry 5 02-21-2011 09:20 AM
replacing window pain: estimate charges mike1127 Off Topic 1 07-09-2010 09:04 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
