Replacing Old Aluminum Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 11:39 AM   #1
Replacing old aluminum windows
I am purchasing a 23 year old house with aluminum windows that have had moderate to severe water damage. Should I replace them with aluminum or go with a different material? The house is in Murrieta, Ca.
Rockmom03 is offline   Reply With Quote
Old 04-27-2012, 11:53 AM   #2
Rewards Points: 14,306
Going to need a picture of the windows.
I personaly would never suggest anyone install metal framed windows.
Most have no thermal brake so the frames frost up. The most likly reason your seeing moisture damage now.
Old 04-27-2012, 11:57 AM   #3
Rewards Points: 528
Actually today Joe, prime aluminum windows all have a thermal break.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
Rockmom03 (04-28-2012)
Old 04-27-2012, 11:59 AM   #4
Would you install them in your own home?
I've seen to many of them start leaking in the outside corners.
Old 04-27-2012, 12:14 PM   #5
Rewards Points: 528
Not where I live, but then again he lives in California and most likely have the temp problem I have.
yes, I have seen aluminum windows that do not leak.
As far as the OP is concerned, I would contact local contractors and see what they recommend.
Worth Replacing Existing Windows? huesmann Windows and Doors 11 10-14-2011 01:59 PM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 06:43 PM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 11:19 AM
Replacing windows from the inside RosenKen Remodeling 3 08-06-2009 12:27 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
