Replacing Insulated Glass In Picture Unit - Simonton - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 10:35 PM   #1
Rewards Points: 14
replacing insulated glass in picture unit - Simonton
The "picture unit" is above the patio door. The exterior pane of the insulated glass has cracked (see 1st pic). The interior side is fine. I found the barcode sticker on the window frame and found out from Simonton Windows that the glass is under a 20 year warranty (from defects and stress crack). I was told by Simonton to contact a local distributor so they can order glass for me.
Honestly - i don't think local distributor will care about go after the warranty for me because the windows were originally installed by Centex (builder) when they built the house 4 years ago. Centex does not warranty anything after 2 years.
My question are...
1) is replacing this insulated glass a DIY job ? I see stops on 4 sides from the interior. To replace the glass, it seems that i need to remove the stops from interior side. Then i should be able to get the glass off. The glass might be "taped" to the exterior side. I don't know yet.
2) typically, do we always have to get replacement through distributor ? Wouldn't Simonton sell replacement directly to me ? The barcode has order # and all the info about the window. So i don't see why i need a distributor to order.
replacing insulated glass in picture unit - Simonton-2012-01-24_07-08-38_618.jpg   replacing insulated glass in picture unit - Simonton-img_1258_op.jpg   replacing insulated glass in picture unit - Simonton-img_1259_op.jpg
mf915 is offline   Reply With Quote
Old 01-26-2012, 11:12 PM   #2
Rewards Points: 14,026
There's lot of reasons for them not to ship direct to customers. but why not call them and ask. They also should be able to put you in touch with a tec that could help figure out how to remove it.
Old 01-27-2012, 07:28 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
It can be a DIY project.
Make sure you wear proper safety gear (gloves, apron, shoes, etc).
It is likely dry glazed with a bonding tape to the exterior.
Make sure you put down drop clothes so as to avoid damage to the floors and prevent the shattering of falling pieces.
As far as who it gets shipped to, couldn't tell you that.
Old 01-27-2012, 09:30 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Simple job to replace, just messy. Take the precautions that WoW mentioned... Pop off the inside stops and if it is dry glazed, it should come out easily. If wet (set in silicone), you'll need to cut that bead from the exterior. There are special tools for doing that, but you can probably find long utility blades at a home store that will do the job.
On shipping it depends on the manufacturer. I frequently have my window manufacturer send warranty window parts to our location for pick up by other clients. Others may send direct. Like Joe said, just ask.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Replacing glass in hurd windows?? slatergrl Remodeling 6 02-04-2008 07:24 PM
Replacing Glass In Windows OVRMYHEAD General DIY Discussions 1 04-26-2007 06:07 PM
Replacing regular glass with low-e in vinyl frame. Doug Crf Building & Construction 1 10-02-2006 06:31 PM
Temporarily Replacing Double Glazing Unit kitefan Building & Construction 6 10-04-2005 01:05 PM
