Replacing The Glass In Single Pane Wood Windows. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 08:20 PM   #1
Replacing the glass in single pane wood windows.
My craftsman style 1 story house was built in 1926, with nice stained woodwork and some old wooden windows with counter weights tied to sash cords. The glazing on the windows needs replaced very badly. Most of the windows dont open due to them being painted shut from the outside. Im going to restore the windows because i want to keep the house somewhat original, and i dont have the money to buy 13 brand new windows. The windows are single pane double hung, with grids in the top sash but not in the bottom sash. The thickness of the glass is barely more than 1/16" (maybe 5/64"?) Some of the panes in a few of the windows are cracked, so I was thinking maybe it's time to replace the glass in ALL of the windows. What glass would give me the best sound proofing and insulating factors from the outside Indiana weather? And would it even be worth replacing all the glass or just the cracked panes? Thanks!
Jeff
Halo2jak is offline   Reply With Quote
Old 05-20-2013, 08:33 PM   #2
I forgot to mention, my current windows are drafty and not good at blocking outside noise. I also don't want glass that's too thick, because then ill need heavy counterweights.
Old 05-21-2013, 04:53 AM   #3
DIY staff
Rewards Points: 7,174
I suggest double strength glass----go to a glass shop and ask about cost and look at the thickness.
Halo2jak (05-28-2013)
Old 05-21-2013, 07:10 AM   #4
Thanks mike! I'm having a glass shop come over and take measurements, and I will ask him when he comes over.
The Following User Says Thank You to Halo2jak For This Useful Post:
oh'mike (05-21-2013)
Old 05-27-2013, 08:21 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
+1 to oh Mike's advice.
Minimum upgrade would be to double strength glass.
After that, see if they have an option for a double pane unit (these will be expensive though).
Do the windows have storms? If not, it would be the time to consider that as well.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Halo2jak (05-28-2013), oh'mike (05-27-2013)
Old 05-27-2013, 04:02 PM   #6
Lord of Slums
Rewards Points: 1,974
I am surprised you would know about the heavier counter weights. So many people do not know that. If you want to do a full restore than remove the glass and all the glaze you can. I use a blow torch, careful with the wood if you are going with a stain. You could use a heat gun as well. Plan on breaking the glass. It is not that hard to cut glass, install it and re glaze. Otherwise, lightly pick out the lose glaze and re glaze, paint the glaze after maybe three months, no sooner, if possible.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
Old 05-28-2013, 10:22 AM   #7
The windows have a track on the bottom half of the outside window opening, but there are no storms. The house didn't have storm windows when we moved in a few years ago. That's something I'm definitely going to look into when fall comes around.
I work at PGW delivering autoglass, so I'm able to deal directly with a glass shop that we service locally, and get prices under retail.
Right now I can get 1/8" double strength glass for the panes at $2 a piece, and big bottom sash glass piece for $7 a piece, putting my cost just above $20 a window. I know they buy 4 x 8 sheets for a lot cheaper than that price, but it seemed reasonable to me since they are taking the time to cut around 110 pieces of glass for my project.
Right now I'm using a heat gun to remove the old glazing and a glazing tool to scrape off the old glazing. It's working all right, but it will be better now that I know I can just be rough with it and break the old glass. Before I was being very careful as to not break the old panes because I wasn't 100% sure about replacing the glass. But I also didn't want my current aged glass next to new replaced glass if I just replaced the broken panes.
Thank you all for your responses!
Jeff
Old 05-28-2013, 01:11 PM   #8
Back glazing?
The panes did not have any back glazing on them when I took them out. Only the glazing on the outside of the window. Should I apply some backglazing to the panes before i put the new glass in? Thanks!
Jeff
Old 05-28-2013, 03:00 PM   #9
Don't really need it if they are glazed properly on the exterior.
Old 05-28-2013, 03:38 PM   #10
Picture of how my windows look.
Oops, the pic is upside down lol. Sorry about that
Old 05-28-2013, 03:41 PM   #11
Current progress on the top sash on window number 1, with one pane fully glazed.
Old 05-28-2013, 05:30 PM   #12
Lord of Slums
One thing, maybe save that old glass if it is real cool looking with the bubbles and thicker at the bottom. If it is just old and nasty then never mind. Also, stainless steel razor blades will NOT scratch glass.
Condensation in middle of window byon49 Windows and Doors 2 10-30-2012 12:26 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
