Replacing Glass On A Bay Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 03:20 PM   #1
Citrix & Cisco Ops
Replacing glass on a bay window
Howdy howdy,
Earlier this year I had a crack develop on one of my bay windows, so I need to replace the glass.
When it comes to taking the glass out, I've gotten about halfway there.
I was able to remove the frame (sash?) with no issue, but I can't figure out how to pop this thing open to remove the glass.
I figure there's someone out there who will take one look at this thing and know exactly what's going on, so I've posted some pictures below
How do I crack this eggshell? Or is it designed to be sealed? Thanks!
RedHelix is offline   Reply With Quote
Old 11-19-2011, 05:03 PM   #2
Registered User
Rewards Points: 5,266
Clean the joint at the stops (thinner strips of wood next to the glass on interior side), then insert a small prybar there starting at the middle working it away from the frame. Try Google if I'm not clear enough.....lol.
Don't use a sander, paint is probably lead based. To get you started: http://books.google.com/books?id=6hu...0prazi&f=false
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
HomeSealed (11-22-2011)
Old 11-21-2011, 01:24 PM   #3
Citrix & Cisco Ops
Edit: oop, nevermind, figured it out
Thanks!
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
Replacing a window whattodo Remodeling 3 03-08-2010 07:51 AM
Replace window in shower with glass blocks organick Kitchen & Bath Remodeling 6 10-10-2009 10:45 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Glass block window position?? justdon Remodeling 4 09-28-2008 07:29 AM
