Replacing double pane french door glass inserts
Came home a few days ago to find the outer glass on one of my double pane french doors still intact, but cracked into a few thousand pieces.
Was quoted $375 by two different glass companies to replace it. Crazy!
After searching online, I see that I can get a new set of doors for that cost.
Found a new unused french door insert leftover from construction for $40 on CL int he same size as mine. New cost $125
Going to try and install it this weekend, any pointers on the install?
They are steel frame with foam core so I assume when I remove all the grid screws the insert should come out somewhat easily except for some caulking.
Doing things almost the right way...
