-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Replacing double pane french door glass inserts (http://www.diychatroom.com/f104/replacing-double-pane-french-door-glass-inserts-147893/)
Double 06-22-2012 08:17 AM
Came home a few days ago to find the outer glass on one of my double pane french doors still intact, but cracked into a few thousand pieces.
Was quoted $375 by two different glass companies to replace it. Crazy!
After searching online, I see that I can get a new set of doors for that cost.
Found a new unused french door insert leftover from construction for $40 on CL int he same size as mine. New cost $125
Going to try and install it this weekend, any pointers on the install?
They are steel frame with foam core so I assume when I remove all the grid screws the insert should come out somewhat easily except for some caulking.
Windows on Wash 06-23-2012 09:59 PM
Be sure to have proper gloves and protection equipment on.
You are on the right track and the glass swap is pretty straightforward.
Double 06-26-2012 08:59 AM
All done. the craigslist add was actually mis-measured and the frame was to narrow, but I found an insert an da builder's upply surplus for $99 and got it installed in about 20 minutes. All in all a pretty seamless job, it worked great.
