Replacing A Curb Mounted Skylight. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-25-2013, 05:46 PM   #1
Replacing a curb mounted skylight.
Hello All, I'm replacing a curb mounted skylight as it leaks a very small amount. I'd really appreciate advice on two point right now- 1) Is it most likely that the leak is occurring in the skylight itself, or by some problem in the curb. Is it likely I need to change the flashing? Our roof was recently redone but the roofer was pretty good. I was warned that the skylight is old, and has been caulked where it should not have been, but where that is I'm not sure. 2) Are the skylights available at big box hardware stores around here (southern Ontario) - columbia and velux specifically - any good? Should I find another brand of skylight. I am looking for a fixed skylight of about 2'x4'. I am unsure if I should get a bubble skylight or a flat tempered glass one. Thanks for any help here -Red Robin
Red Robin is offline   Reply With Quote
Old 07-25-2013, 06:12 PM   #2
Rewards Points: 13,750
No clue without a picture.
No not but a cheap bubble style!!!
Velex is a good brand.
Any box store, or local lumber yard will have or can get one.
Old 07-25-2013, 07:50 PM   #3
Rewards Points: 648
I would replace the curb flashing's if they weren't redone with the last roof. Velux is good quality, and they have a plant right in Mississauga.
PatChap is offline   Reply With Quote
Tags
flashing , install , leak , skylight
Does skylight need replacing? Ttd0715 Roofing/Siding 17 01-14-2012 03:39 PM
New Roof and Skylights JRMN Roofing/Siding 12 10-13-2011 07:29 AM
where to find this type of skylight domes? diybeginner123 Roofing/Siding 5 09-27-2011 08:48 PM
Deck mounted faucet replacing cost. Sonusingh Plumbing 9 06-16-2011 11:36 AM
when to replace a skylight & flashing question CindiChm Roofing/Siding 3 10-08-2007 09:18 AM
