#1 |
Replacing cracked caulking around window
Hey everyone,
So I just bought a new house and found a couple places where caulking has cracked around a window, in some places it's big enough that you can see daylight through. It looks like it would be an easy fix, but just wanted to ask how I should go about this: Do I need to remove the old caulking first, or should I just try to put a little in to seal up the crack? Also, is there a particular type of caulk I should be using - silicon? all-purpose? etc.? Thanks in advance for any help you can provide.
#2 |
"Nail-Bender"
Try to remove as much of the old caulking that you can.
Use "OSI" Quad or "NPT" Solar Seal. RF |
#3 |
No idea of what that's suppost to be a picture of.
New caulking will not stick to old, so the old has to go. Someone used way to much caulking when caulking that window. You only need enough to fill the gap not all over the trin and the window. Do not use silicon, it can not be painted. I use Alex 230, it's water clean up, 50 year warrenty, paintable. I just hate working with Quad, it stick great but it's a total mess to clean up on the trim and your hands while using it. |
#4 |
Mod
I know of no other caulking that sticks (and stays stuck) better than a polyurethane based caulk (Quad or Vulkem) especially against masonry.
There is defiantly a learning curve to using the stuff without making a mess of things. A rag and a jug of thinner at your side is mandatory. I hate working with the stuff. Between the caulking and the thinner you end up smelling like you bathed in diesel fuel by the end of the day. I still use it regardless of it being user friendly or not because I believe it will out preform anything DAP has to offer. What does a 50 year warranty mean anyway??? Save the empty tubes and the receipt. Here's the warranty for 230 from DAP. 50-Year Satisfaction Guarantee: If not satisfied with product performance during guarantee period, return used container and sales receipt to DAP Products Inc., Technical Customer Service, 2400 Boston St., Ste. 200, Baltimore, MD, 21224 for sales price refund. DAP is not liable for incidental or consequential damages.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 07-30-2012 at 07:04 PM. |
#5 |
gravity always wins
Yeah! I know I put those empty caulk tubes and the reciept in my safe deposit box so that when I'm a hundred years old I can return them for my full refund.
#6 |
Windows & Remodeling
Another vote for quad, vulkem, and/or solar seal. They are actually very easy to work with if you work with them regularly, but the key is that you need to be able to lay a nice bead without tooling. If you are going to need to tool it, you may be better off with some of that cheaper stuff.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Exterior Construction
Quad is sort of the industry standard now and day.
Be aware that in a confined space, you are going to need some circulation and fresh air.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 | |
Replacing cracked caulking around windowQuote:
Hoping that whoever did the flashing was just sloppy.It also says xylene or toluene are recommended for cleanup, as opposed to paint thinner/mineral spirits. Seems to depend on the product, not necessarily the main advertised ingredient (different proportions etc.); be sure to read the label before you go getting any on yourself. best to wear gloves. That damaged caulking on the window looks to be inside. Do the outside with something polyurethane-based (several recommendations above), and the inside with acrylic. It's not like the inside part will get wet, and you don't have to worry about messy stuff that is difficult to clean up and smells horrible. Acrylic will still resist moisture, it's just not as durable, which is a non-issue indoors/away from water. |
#9 |
Mod
Never read the tube (don't use it), I got that off the TB http://www.dap.com/docs/tech/00010057101.pdf Bottom of the page.
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 08-08-2012 at 06:52 PM. |
| Display Modes | |
| Replacing old kitchen window with new construction window | speedster1 | Windows and Doors | 2 | 06-29-2012 01:13 AM |
| Replacing Small Cracked Porch/Slab (with pictures) | JasonCA | Concrete, Stone & Masonry | 2 | 03-24-2012 09:47 PM |
| Replacing panes in a Pella window | Richo | Building & Construction | 5 | 09-11-2009 10:20 PM |
| Where stucco meets the window & door; caulking | Longleaf | Building & Construction | 12 | 08-12-2008 05:46 PM |
| fixing cracked caulking on mdf painted trim | cinnabon | Painting | 5 | 04-15-2008 05:49 AM |
