Replacing Cladding On A Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 11:23 AM   #1
Replacing cladding on a door
I have Anderson Pattio Door, inside swing with vinyl cladding on the outside. When the windows were 10 years old the vinyl peeled and Anderson said the windows where actually made 10 years and six months ago so there was no warranty. The warranty starts the days the item is made. For six years I've patched and caulked. I would like to remove the vinyl and glue on new material. Exellent adhesives are now available. Has anyone done this?
greyhead is offline   Reply With Quote
Old 06-29-2011, 06:52 AM   #2
This is unusual for an Andersen product, and there is a ten year warranty on such problems, but I am surprised at their response. When the door was installed, there was a warranty card stating the installed date, they should honor that. I have had few issues with their products, but they have always taken care of them quickly.
Old 05-07-2013, 08:31 AM   #3
Anderson Patio door vinyl cladding separation
I have an Anderson patio door (French doors) with vinyl cladding outside. It's 13 years old and 2 years ago, the vinyl started separating from wood panel. I have glued several times but only last 4-6 months. Any feedback on how to repair would be appreciated since its no longer under warranty.
Jkinnamon is offline   Reply With Quote
Old 05-07-2013, 09:24 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I have had a few clients with similar experience to the OP. Once the warranty is up, Andersen washes their hands of it. Actually had one recently where we replaced some 9 year old Renewals that they would not warranty with the woodgrain interior blistering and peeling up. Not sure what the exact reasoning for the denial was, but I know that the current homeowner was not the original purchaser. Also, to be fair to Andersen, the my experience with warranty coverage has been fairly similar across the board as wood products go, with the exception of Marvin whom I've seen bend over backwards on more than one occasion, even when products were more than a year out of warranty.
Regarding a fix for the issues described, there is nothing you can do that will be anything more than a band-aid. Either reattach the original cladding with adhesive, or you could possibly have someone come out and clad it with custom bent aluminum, but neither option will be a long term fix, nor will it provided a stellar fit and finish.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-08-2013, 07:48 AM   #5
Spoke with Anderson yesterday. Although my warranty expired in 2009, they offered to replace the doors at 30% of retail, cover shipping, and provide another 10 year warranty. HomeSealed, thanks for response, for the cost, it makes sense to replace instead of continuous maintenance.
Old 05-08-2013, 04:57 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Not a bad deal that they've offered. Kudos to Andersen
www.HomeSealed.com
Old 05-08-2013, 05:54 PM   #7
Rewards Points: 2,240
It's good to see Andersen; starting to react to so much -
"bad press"!
rossfingal is offline   Reply With Quote
Replacing a door & header on loadbearing wall 2ocnorb Introductions 2 08-06-2010 06:39 AM
replacing door to linen closet Danskier Carpentry 2 12-24-2009 12:17 PM
Replacing windows with sliding patio door, should I match widths? TomServo Building & Construction 5 09-21-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
