Replacement Windows Worth It? - Windows and Doors - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 11:20 PM   #31
MJW
Originally Posted by bryanp22 View Post
MJW you did all that yourself? Was that the first time you had replaced windows and siding? How long did it take you?
I'm not a diy'er. I do this for a living. That dormer (in it's entirety) took about an hour or so. I didn't replace the window. It was only about 6 or 7 years old at the time.
That job was a storm damage job. It consisted of roofing, siding, and fascia. This dormer faced the road and driveway, so the homeowner wanted to dress it up a bit.
MJW is offline   Reply With Quote
Old 02-08-2012, 04:26 AM   #32
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
Nice work MJW!
Originally Posted by MJW View Post
Here is one I did (siding, roof, soffit, fascia's) with 1x4's and wrapped with aluminum coil. Just imagine the aluminum wrapped 1x as an Azek (or similar) board. If you don't know what that is, just do a search. Certainteed has something similar also. Of course do proper flashing, taping, and insulating. A new construction window may cause you to do new trim and jambs inside also, but well worth it in the end.
These are all just suggestions, so you can make up your own mind. I think most will agree that new construction windows are best especially if already planning on doing siding.
Your timeline will definitely make a difference on what you do and what you can handle yourself.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
MJW (02-08-2012), Tom Struble (02-08-2012)
Old 02-09-2012, 03:19 PM   #33
bryanp22's Avatar
Rewards Points: 290
My fiancÚ asked me why our windows have almost a set back look compared to some neighbors. From the pictures I posted earlier can anyone confirm why that is? Is it just how the siding and windows were trimmed?
bryanp22 is offline   Reply With Quote
Old 02-09-2012, 03:38 PM   #34
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Yours is very conventional for the age of your home. Is it possible that your neighbors have newer homes, ie: newer windows installed with a nailing fin? That type of install will have a jamb extension and look more "set back" from the inside rather than the outside... It usually has to do with the type of window, but the trim and other factors can play a role as well.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Vinyl replacement windows. joefromcal Building & Construction 8 02-20-2011 09:54 PM
Insulated Windows - Worth the extra money? VinDan Remodeling 10 07-30-2010 07:01 PM
Anderson Casement Windows is it Worth Repairing? MCASEY328 Building & Construction 2 07-28-2010 08:25 PM
measuring for replacement windows bc0604@yahoo.com Remodeling 8 01-19-2009 12:22 PM
