Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-14-2011, 02:42 PM   #1
Replacement windows for old home.
The old home has wood all around including casing trim, how do I measure and how do I install repalcement windows. Do I have to remove all the framing trim
Patiopro is offline   Reply With Quote
Old 11-14-2011, 04:47 PM   #2
Windows & Remodeling
HomeSealed's Avatar
Here is one link:http://www.youtube.com/watch?v=-LUMWT0-PaQ ...but I'd recommend recommend watching a couple more to familiarize yourself with the process. There are also step by step diagrams out there, as well as instruction that will come with the window- although those usually assume a base of installation knowledge.
Key points: -Measure accurately
-Get the window installed square (check reveals)
-Make sure that it is properly insulated, flashed, and sealed
HomeSealed is offline   Reply With Quote
Old 11-14-2011, 05:58 PM   #3
MJW
Yep, that's how they do it. Measure, order, set, seal. Not a whole lot to it with insert replacements.
MJW is offline   Reply With Quote
Old 11-14-2011, 06:21 PM   #4
Moderator
kwikfishron's Avatar
I don’t like relying on caulk as the primary defense against the weather.
The ONLY time I’ll use inserts is when retaining the sloped sill and trim details of a old home is the primary goal.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
New replacement windows got wet - Problem? scnd1016 Windows and Doors 1 07-10-2011 07:47 AM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
Replacement Windows? Asbestos Shingles? I have NO CLUE! Evil Scotsman Carpentry 2 10-19-2010 01:01 PM
replacement windows in stucco houser Building & Construction 3 08-23-2007 12:28 AM
