Replacement Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 01:29 AM   #1
Replacement Windows
Hello All,
First time member and I'm torn between the Anderson 400 Tilt Wash windows and their subsidiary American Craftsman ( a vinyl replacement ) - that is also sold at Home Depot.
My issue is that there are a few windows in the house that have box air conditioners, and being that the Anderson is a wood frame window, I'm afraid that the weather elements - rain, etc. will then ruin the inside of the window when it's open. I'm sure that I can fashion a support to hold the bottom of the A/C when it's placed in the window.
Is there any means to protect the inside side jambs and bottom of the window when the unit is in place?
Should I coat the wood with a sealer?
Otherwise the vinyl replacement appears to be the alternate choice.
By the way, this is a cool site.
Thanks,
Mdeange
mdeange is offline   Reply With Quote
Old 08-16-2012, 01:41 AM   #2
Registered User
Rewards Points: 5,236
Welcome! I'll move you to "Windows"
Gary
Old 08-16-2012, 08:28 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
The 400 series in this case is a vinyl clad wood. No additional sealer is required on the sills, jambs, or exterior surfaces.
If you are getting water to the inside of the home, the air conditioner and trim kit was not properly installed.
Those are also two considerably different windows from a quality standpoint.
If vinyl is deemed to be suitable, I highly suggest that you look at other brands or if you are considering a DIY option, the Simonton equivalent also at Home Depot.
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 09:56 AM
Replacement windows StanDavid Building & Construction 8 03-13-2011 04:37 PM
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 04:48 PM
Vinyl replacement Windows AdRock Remodeling 9 08-05-2009 09:56 AM
Vinyl Replacement Windows fixiechick General DIY Discussions 56 04-20-2009 06:37 PM
