-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Replacement window insulation (http://www.diychatroom.com/f104/replacement-window-insulation-160546/)
Orbit 10-19-2012 09:48 AM
I am allergic to everything! So I'd rather not insulate the window cavities when they put in replacement windows. 1) Does isocyante foam cure COMPLETELY inside those cavities on the sides of the windows? 2) How much heat loss can I expect by not insulating them? They're not insulated now (150 year old house.) House in New England.
Windows on Wash 10-19-2012 12:24 PM
It is not polyisocyanurate foam that would likely be installed in those cavities.
You can remove the weight box cover and install batting of some sort (recommend to use something like Roxul) and there shouldn't be anything offensive to you allergies in that.
If you do have foam injected in it, it would be polyurethane and after a day or so, there is no smell to it.
joecaption 10-19-2012 03:32 PM
For the smaller gaps you could use Dap Latex foam.
Windows on Wash 10-19-2012 07:34 PM
The latex foams have VOCs s well. Both shouldn't smell that bad once they are cured up.
HomeSealed 10-20-2012 08:34 AM
+1 on insulating/sealing those cavities. Always a good idea. :)
