Replacement Window Install Question. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 04:45 PM   #1
Replacement window install question.
Jusy finished installing a vinyl replacement window... First time. Everything went well, but my outside blind stops seemed to be not plumb (slightly). So when I put the window in, towards the top it did not press up snug on the outside stop. I know the stops don't support the window, but is it ok that I just caulked the small gap between the outside stop and the front of the window? Window operates fine and is square and level, but want to know if I need to worry about water or something? thanks!
joshg3p0 is offline   Reply With Quote
Old 06-02-2012, 08:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
Should be fine.
Old 06-03-2012, 07:39 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. As long as the window is square and sealed, you should be fine.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-05-2012, 03:53 PM   #4
I think the original stool was notched poorly (perhaps the wall was not square). I can see the aluminum tracks were kind of pinching between the stool and outside stop. Anyway, I think it's making the window fit between the stool and blind stops tight on the bottom, and not allowing me to push the window out flush against the stops towards the top. Does that make sense? has anyone seen this type of thing happen?
Old 06-05-2012, 08:24 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
over the years the stop/window trim can separate from the window frame
sometimes the resulting gap gets filled with caulk sometimes not
I usually smack the head/rail trim with a hammer to set it back,if i see alot of movement ill set it with a deck screw
Tom Struble is offline   Reply With Quote
Old 06-05-2012, 10:32 PM   #6
Here's the pinching of the aluminum jamb liner. Leads me to think the very bottom distance of stool to outside stop is slightly less than 3 1/4"?
The Following 2 Users Say Thank You to joshg3p0 For This Useful Post:
Tom Struble (06-06-2012), Windows on Wash (06-06-2012)
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 09:34 AM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
