Replacement Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-31-2013, 12:30 PM   #1
Rewards Points: 396
Replacement window
Hello,
I know replacement windows aren't meant to be installed in an existing window frame but can you use them as new const. windows in a bare rough opening? Reason I ask is because my house is brick sided so using a window with a nailing flange wouldn't really work.
detroittigerfan is offline   Reply With Quote
Old 10-31-2013, 01:42 PM   #2
Rewards Points: 14,014
Then use a brick mold window. It will have a built in brick moulding.
Or a flat jamb window and add your own trim, it will come with a built in sill.
http://www.trimlinewindows.com/brickmold.asp
Replacement window are just the shape of a box and you not have a built in sill.
Old 10-31-2013, 03:59 PM   #3
Rewards Points: 396
if I did a brick mould new const. window would the bottom of the brick mould reach the top of the lower section of brick?
Old 10-31-2013, 04:29 PM   #4
The sill sits on top of the soldered bricks, not the brick moulding.
The brick moulding ends on top of the sill just like the way any regular window does.
Old 10-31-2013, 05:36 PM   #5
Rewards Points: 396
If i went with a brick mould window that has not sill would I still need a sill?
Old 10-31-2013, 07:29 PM   #6
Rewards Points: 396
If you order a new const. window with brick mould will it still have those nailing flanges? If so, they can be cut off, correct?
how to secure replacement casement window tambo Windows and Doors 5 08-10-2012 11:49 AM
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 07:27 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
