Replacement Of Garage Door Panels - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 04:25 PM   #1
Replacement of garage door panels
I am a nube and am glad that I have found this forum and have joined. I have a two car garage with two doors one of which has two panels, the bottom and next one up that have been damaged by insects and dry rot. The door is an old style wood with masonite inserts. I have been able to obtain some used replacement panels and saw on line that the panels can be replaced without removing the whole door by just removing the bad panels and replacing them with the "new" ones. Has anyone ever used this method and do you have some advice on hoe to approach it...thanks!
BeanCntr is offline   Reply With Quote
Old 07-31-2012, 05:18 PM   #2
Rewards Points: 13,712
Not sure what info you need, preprime and paint the panels, remove the old from the inside and replace.
Most often an old wood door is just not worth the time to repair. T ake a close look at the cross members, if there bad time for a new aluminum or steel door.
Old 08-01-2012, 09:38 AM   #3
Garage door panels
Joe--appreciate the info, what I was trying to get at was if there is a way to replace the two bottom panels without pulling all of the panels out of the door; i.e removing the very top panel, then the third panel, then the second panel and then the bottom panel and replacing in reverse order. I saw a video on you tube where a guy left the two top panels in place and removed and replaced the bottom two. What I was wondering is how you secure the cables springs etc if it can be done that way...seems like it would be easier than pulling out the entire door...thanks again
Old 08-03-2012, 09:54 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Messing with the bottom panel of a sectional garage door is not typically DIY work. The bottom roller brackets carry all of the spring tension. Working with the bottom brackets in the closed position is exceedingly dangerous unless you know exactly how to go about it. I've only ever done it on big doors that were collision damaged and could not be safely raised. It is possible to remove the masonite panels and replace them. Usually you have to trim the stops away with a router and then cut new stops to hold the panels in place. A good grade of exterior plywood is better than masonite for a replacement.
MWBC to Garage Questions benleef Electrical 3 02-22-2012 11:02 AM
Garage Door Header Replacement dannyoung85 Building & Construction 7 11-14-2011 09:33 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 01:08 PM
Garage Lighting Replacement burnt03 Electrical 4 10-13-2009 07:35 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
