Replacement Basement Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 02:56 PM   #1
I have 3 basement windows in need of replacing. They are single pane sliding type. Air leakage is the issue as well as generally falling apart. They measure 12 x 30 inches. Poured concrete foundation. Is this size a hard size for replacments? I have looked around with no luck. Thanks, Julie
jasavoye is offline   Reply With Quote
Old 01-03-2012, 03:08 PM   #2
Rewards Points: 14,312
What you need is what's called a hopper window.
Any siding supply, Lowes and Home Depot can special order them for you.
It's not a big deal, most vinyl windows are custom made.
Old 01-03-2012, 03:20 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The height is on the short side. Many vinyl manufacturers won't go that small, as 13-14" are common minimums. I know there are a few though that do. I'd recommend calling a local building supply house (like ABC or Allied). They'll have access to more options there, plus you'll probably deal with someone that knows what the heck they are talking about-- unlike the box stores.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-03-2012, 04:58 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Also be prepared that the opening size (viewable glass) will decrease slightly with a replacement window.
Old 01-03-2012, 05:47 PM   #5
Rewards Points: 183
You can also replace the windows with glass block windows. A small jalousie window can be installed in the glass block.
paul100 is offline   Reply With Quote
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
Replacement windows - flashing question smoenra General DIY Discussions 0 11-01-2011 11:07 PM
Vinyl replacement windows. joefromcal Building & Construction 8 02-20-2011 09:54 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
Basement Window Replacement mebsdad Building & Construction 2 02-19-2007 08:10 AM
