#1 |
Replace a string balance on a reliabilt 3500 window
How do you remove and replace a string with pulley balance on a reliabilt window mfg'd in '09 ?
It is made for a tilt-in window. |
#2 |
Disabled wood vet
Can you get to it from behind the trim? I don't know. I've never seen one.
#3 |
Exterior Construction
It should be a vinyl tilt in window.
In that application, you wouldn't bother with replacing the string. Replace the whole balance assembly. It is pretty easy and is usually only held in place by 1 or 2 screws. Look at the balance tube and get the number off of it and call Reliabilt. They should be able to get you the replacement either under warranty or for a small fee.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Windows & Remodeling
+1. I dont know that product inside and out, but it sounds like a block and tackle balance. As WoW said, couple screws is all it takes. They are one of the easiest balance assemblies to replace.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Window UNDER siding. How to properly replace? | Alan | Building & Construction | 7 | 03-14-2011 12:57 AM |
| How hard to replace window screens? | TomBrooklyn | Building & Construction | 4 | 01-04-2009 10:03 AM |
| Code requirement to replace bathroom window. | Rem8 | Building & Construction | 5 | 06-16-2008 03:57 PM |
| spring balance in old wood window | Kbotard | Carpentry | 6 | 05-19-2007 10:32 PM |
