Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-08-2011, 08:32 PM   #1
replace rotting wood
How do I remove and replace rotting wood on my sliding glass door?
William Vidmar is offline   Reply With Quote
Old 07-08-2011, 09:48 PM   #2
Super Moderator
You are in trouble---Generally if the sash is rotting the door is done--junk.
Post a picture if you can---I repair a lot of rotting window sills but the cost in time and skills and tooling to rebuild a sash has always made replacement the better option.
Old 07-09-2011, 07:42 AM   #3
What he said, but most manufacturers guarantee such things for 10 yrs. If older than that, replcement is usually the option. There are wood epoxy systems that might prolong the inevitable, but you need to dig out the rot, fill and sand the epoxy.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Very old house replace all basement wood beams? HQZ Building & Construction 14 09-25-2010 10:11 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
