Replace Replacement Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 07:07 PM   #1
always learning
replace replacement windows
I would like to replace my replacement windows. The former owner bought the cheapest replacement windows he could. Now all the seals are broken and there is no thermal barrier.
My question is, where would I measure the old replacement windows to correctly fit new replacement windows?
theone is offline   Reply With Quote
Old 10-17-2011, 09:44 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The fool-proof way would be to pull of the stops and just measure the window that is already in there... Otherwise, measure from the insde of each interior stop, then add 3/8".... You'll be guaranteed to cover, and give yourself the necessary space to make sure you're able to get the new window installed square.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-18-2011, 08:42 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
+1
Pull the stops on one window and see what the additional depth is. Once you have that measurement, you can just ad it to the inside measurements on the rest of the windows.
The Following User Says Thank You to Windows on Wash For This Useful Post:
theone (10-19-2011)
Old 10-19-2011, 09:16 PM   #4
always learning
easy enough guys...... thanks
Replacement windows StanDavid Building & Construction 8 03-13-2011 03:37 PM
Vinyl replacement windows. joefromcal Building & Construction 8 02-20-2011 09:54 PM
Replacement Windows lucky8926 Building & Construction 36 10-13-2010 11:09 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
replacement windows in stucco houser Building & Construction 3 08-22-2007 11:28 PM
