Replace Glass Slider With Screen - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 12:11 AM   #1
Rewards Points: 27
Replace Glass Slider with Screen
A friend is getting married in a week and wants some work done on his new apartment. Two bedroom windows face out onto the main street and he wanted the bottom slider to have a screen. My assumption was that he would have to have them custom made to the size of the window with new frames -- he thought I could just take out the glass and somehow put in a screen. Any thoughts on this? How much per window would it cost to get one of the sliders as a screen?
Replace Glass Slider with Screen-image-959533465.jpg   Replace Glass Slider with Screen-image-643750867.jpg
RomanDesign is offline   Reply With Quote
Old 06-02-2012, 12:21 AM   #2
Rewards Points: 6,652
You are going to have to talk to either your local Ace hardware to see what they can do, or the property owners of the apartment building to see what they suggest. No, you just can not take glass out of a window and replace with screening. If you want screens, you either need Storm windows with screens, or can pick up the screen inserts that they sell at your local hardware store, that expand to fit the window frame, or clamp over the face of the frame. The later you usually have to custom order, if the window is not a standard size.
Due to more people having allergies, rhinitis, etc, less people are opening their windows and opting to run their hvac 24/7 365 to keep somewhat of a "clean" air environment in the residence.
Old 06-02-2012, 01:01 AM   #3
Rewards Points: 27
I figured I would have to probably talk with a local window expert -- I'll do that and see what I can come up with. Thanks
Old 06-02-2012, 10:29 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Take some pics and dimensions to a local glass shop. They can fab up a screen unit for you relatively inexpensively that should operate as the original did.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Cannot Unlatch Glass Slider dynaco120 Windows and Doors 5 03-14-2015 08:09 PM
cabinet door glass Master Brian Carpentry 6 03-23-2012 09:55 PM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 12:21 PM
Condensation ring on Pella window captjackny HVAC 59 01-04-2012 08:08 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 06:24 PM
