#1 |
Repairing nail holes in fiberglass doors?
I've patched a lot of screw holes in wooden doors (keyset screws) with toothpicks and wood glue, but I've been working with fiberglass doors recently. I wonder if there is any way to patch stripped screw holes in fiberglass as well?
#2 |
Exterior Construction
Fiberglass repair kits. Available at most Auto Parts stores.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
I'd suggest a two part epoxy like West System. (as suggested they sell a small two part package that comes with a tonge depressor for mixing it) Any boating supply will have it and also a special needle so you can shoot it into a small hole.
Tape off any areas with wax paper and painters tape you do not want it to get one. Once it sets up it's imposable to get off with out sanding. Mix in a plastic or glass bowl, not a small cup. I often use those cheap Dollar store Tupper Ware looking containers. In a small cup it would set up before it can be applyed. Wear rubber gloves! It's as bad as super glue to work with. Last edited by joecaption; 10-19-2012 at 09:32 AM. |
| Display Modes | |
| Nail Shear Strength Test | ddawg16 | Building & Construction | 32 | 08-24-2012 10:17 PM |
| Is tape necessary to repair holes in drywall (in garage)? | Scotch99 | Drywall & Plaster | 4 | 08-22-2011 02:08 PM |
| Using I&W with nail holes in it | windsor02 | Roofing/Siding | 3 | 08-04-2011 08:24 PM |
| It's hot outside. Keep the exterior doors and windows closed if running the A/C? | Taylor Crockett | HVAC | 3 | 07-07-2008 06:04 PM |
| repairing damaged wood on older doors, frames, etc (peeling, chipped, etc) | joeyboy | Carpentry | 9 | 10-03-2007 09:33 PM |
