Repair Thermal Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 09:15 PM   #1
Question
Repair thermal windows?
Just moved in to a 12 year old condo and my insulated windows have a cloudy look and seem to have some condensation. Can these be repaired: better to replace; better yet replace the entire window?
davidmartin is offline   Reply With Quote
Old 02-06-2012, 09:28 PM   #2
Rewards Points: 582
[quote=davidmartin;846432]Just moved in to a 12 year old condo and my insulated windows have a cloudy look and seem to have some condensation. Can these be repaired: better to replace; better yet replace the entire window?[/quote the windows should be replaced have not seen to many repairs that was worth it ....
Old 02-07-2012, 06:43 AM   #3
The seal that divides the glass is bad. The glass will need to be replaced. Depending on how the windows were put together, you may have to replace the sash. If less than 20 yrs old, there may be a warranty on that type failure. If you can't find the manufacturers name anywhere(look for stickers on the sash edges or on the frame under the sashes), it might be best to replace the window with a quality unit and high efficiency glass. No name windows are usually crap.
There are usually local companies that can make insulated replacement glass.
The Following User Says Thank You to Just Bill For This Useful Post:
davidmartin (02-07-2012)
Old 02-07-2012, 07:38 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
They can be "repaired" by some companies that will drill and vent the air space in the IGU. If they are 12 years old, see if you can find out who made the windows first. They may be under warranty for that matter.
Start there. If you find out who made them, they can very likely provide the replacement sashes as well and a cost effective price and that is far easier than re-glazing the window.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 02-07-2012, 08:35 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
All of the above advice is pretty good... First see if they are under warranty, if not, replace the sash or glass... or... if they are "builder grade" quality (which is likely), weigh the cost of replacement with a better unit.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows? Erickp40 Windows and Doors 5 11-17-2011 10:53 AM
Replacement windows - flashing question smoenra General DIY Discussions 0 11-01-2011 11:07 PM
New windows and doors for remodeling Andee77 Building & Construction 2 10-10-2011 02:27 PM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
