Renter - Door Ideas - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 02:58 PM   #1
Renter - Door ideas
Hi everyone,
Thanks for providing this great resource.
I live in a rental property, and my housemate's room has no door. The landlord is already dealing with a ton of leaks, etc, and I don't want to burden him further, but a cotton curtain really isn't cutting it. We are looking for ideas for a secure, locking room divider that would be quite inexpensive and not cause lasting alteration to the property.
The space used to have double French doors, quite tall. around 7.5/8 feet. It's approx. 4 feet wide. Hinges are still up from the old doors.
Thanks again!
-Ellen
DandelionSeed is offline   Reply With Quote
Old 03-03-2013, 03:10 PM   #2
Habitat for Humanity reuse stores usually have a ton of doors to choose from. You could get a replacement there maybe
creeper is offline   Reply With Quote
Old 03-03-2013, 03:37 PM   #3
Resale store mesuare the opening and look for two doors that will fill the opening.
Hardway is offline   Reply With Quote
Old 03-03-2013, 09:43 PM   #4
Rewards Points: 216
a sheet of plywood. cut it to almost exact fit. screw it to the existing hinges. put jam moldings on. then a latch to hold it closed.
Fix'n it is offline   Reply With Quote
Old 03-04-2013, 02:02 PM   #5
Thanks much, all! Will look into these options.
Old 03-21-2013, 01:24 AM   #6
There are lot of cheap room dividers available that could be the solution for your privacy. Since the hinges are already there use a large diameter PVC pipe and hang a clothesline of your choice.
Door closers India | Fire Door hardware
Sridhar Raj is offline   Reply With Quote
Daughter is first time apt. renter gregzoll General DIY Discussions 10 09-29-2011 10:18 PM
Health concerns with a renter crawl space Brentmerrifield Building & Construction 3 07-15-2011 08:43 AM
Renter seeking advice for sealing around pipes bookryder Plumbing 4 07-08-2010 10:31 PM
Renter laying laminate? FernStar Flooring 9 05-22-2009 10:58 AM
