Removing Windows.... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 08:58 AM   #1
removing windows....
I just bought a 1950's colonial and it has 2 windows in the kitchen corner.. one on each wall that I would like to remove to put in a 1/2 bath.
my question is once I remove the window/frame should i reinforce the window hole with a 2x4? or is that a bit overkill if the window was already framed in properly?
THanks!
jarheadoo7 is offline   Reply With Quote
Old 06-08-2011, 06:30 AM   #2
Yes, strengthening is not needed. Assuming you are closing the window holes, just build 2x4 framing and insert, then sheath the exterior, insulate and cover the inside as needed.
Old 06-08-2011, 10:13 AM   #3
All Glass's Avatar
Need Strengthing?
Probably not because when they frame the walls to accept a window or door, the framing is built to give the jambs, sill, and header added strength for the window or door, and to make up for the missing framing that would normally be there.
All Glass is offline   Reply With Quote
Old 06-09-2011, 10:41 PM   #4
Registered User
Rewards Points: 5,498
It depends on the sheathing span for side-wall, the on-center spacing......
Gary
Windows in New Construction sok454 Building & Construction 8 02-28-2011 11:09 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 06:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
