Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-13-2011, 10:36 AM   #1
removing stationary glass sliding door
it have removed the obvious screws but it will not move
FranCece is offline   Reply With Quote
Old 07-13-2011, 10:49 AM   #2
Super Moderator
There are more than one blend of doors---take a picture-----
On many there are two small 'L' brackets that are all that hold it in--one top and one bottom on the exposed edge in the center of the frame.
Remove those and slide the door over--a gentle hand and a thin flat bar will help.
Old 07-13-2011, 11:54 AM   #3
Framing Contractor
I have seen some old sliders that have the fixed panel screwed in through the frame. Dumb idea, but I have seen it.
sixeightten is offline   Reply With Quote
Pella sliding glass door trim seperated from glass Scuba_Dave Building & Construction 6 03-10-2011 01:28 PM
Sliding Glass Door schercon82 General Discussion 5 01-10-2011 07:05 AM
fill gap between brick and new glass sliding door CarpenterJill Carpentry 1 11-07-2010 03:45 PM
How to install sliding glass door/french door dkgetz Carpentry 4 03-15-2010 02:03 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
