removing sliding vinyl window
There are "bumpers" in the head jamb that prevent the sashes from being lifted out. Make sure that you've slid the sash past those. (they are removable if need be). If you're past that and still having issues, then you just need some old-fashioned elbow grease because the head jamb is probably sagging... You could try to "suck" it back up with a screw as well.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
