Removing A Slider Window - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 05:29 PM   #16
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Originally Posted by concretemasonry View Post
jon -
Despite the 5x5 window, the "wrinkled tin" well could inhibit the ability to get a long (12') x 4.5' sheet oriented and threaded down and turned around.
Dick
Yeah, I'll measure it again, but it seems like it would come down okay. I don't have to make any kinds of turns. I have a good 18 feet in front of the window to slide it straight down through the window. Worse case scenario is I can cut them down to 11' since my longest wall is 10.5'. I've never done any drywalling before so the less seems the better
jonhayden is offline   Reply With Quote
Old 04-16-2013, 05:32 PM   #17
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Originally Posted by rossfingal View Post
What "jonhayden" means - the sheets aren't 4.5 ft. - the ceilings are 9 ft.
So - going to have either have a 1 ft. strip of drywall (if run horizontally)
Or run the sheets vertically.
"RF"
No, the sheets are 54" wide so I can stack 2 sheets to make the 9' ceiling. You have to special order them though. Home Depot quoted me $19 a sheet. I'm surprised these aren't common now since most new basements are 9'. I don't want to hang vertically.
The Following User Says Thank You to jonhayden For This Useful Post:
HomeSealed (04-16-2013)
Old 04-16-2013, 05:43 PM   #18
Rewards Points: 2,240
54 inches wide? - that's cool -
you should still be able to get them in.
We don't like "special order"!
We would hang them vertically -
No "butt" joints.
Whatever "floats your boat"!
"RF"
rossfingal is offline   Reply With Quote
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 07:51 PM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 01:48 PM
Slider window Rob461 General DIY Discussions 3 01-24-2011 10:40 AM
Removing window and patching stucco mark_anderson_u Remodeling 4 12-27-2010 11:04 AM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
