Removing A Slider Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 05:53 PM   #1
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Removing a slider window
I need to pop out the window in my basement egress window so I can get some drywall brought down to the basement. It appears to be a Majestic horizontal slider window. The sliding window pops out without any problems, but I'm wondering how to remove the stationary window. I've read that with windows like this, you can typically remove the vertical bar and then the stationary window can be popped out too. But I can't figure out how to remove the vertical bar. I attached some pictures. Any help would be appreciated.
Thanks,
Jon
jonhayden is offline   Reply With Quote
Old 04-16-2013, 08:01 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,958
Look for some L-brackets and screws on the mullion post. If you can't see any, it may have been screwed in from the backside to start with and in that case, you would have to remove the window to disassemble or just remove the window altogether and replace.
Old 04-16-2013, 09:30 AM   #3
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Thanks. I'll take a look. I wonder how hard it would be to remove the entire window. Looks like there are only 2 tapcon screws on the left and right side that hold it in. And also some silicon caulking. Do you think that's all there is to removing it? Just remove the 4 screws and cut the caulking?
Old 04-16-2013, 10:58 AM   #4
If it was set retrofit, yes.
If it was put in with a fin and in the form, no.
Old 04-16-2013, 11:56 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. You should be able to just pull those tapcons and slide it out. Probably screwed from the outside of the frame, or there is an interlocking tab or something along those lines.
Different procedures are more common in various regions, but it is rare to see a basement window set in a poured foundation with a nailing fin in my experience...
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-16-2013, 12:21 PM   #6
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Yep, I just found a picture of window opening after the foundation was poured. I don't think anything was set inside the concrete.
Old 04-16-2013, 12:25 PM   #7
Rewards Points: 2,238
That's an "escape"/"egress" window -
make sure you take that into consideration when installing a new window!
Cut the caulk, remove the tapcons -
it should come out.
rossfingal
rossfingal is offline   Reply With Quote
Old 04-16-2013, 12:27 PM   #8
Want to Learn
jonhayden's Avatar
Rewards Points: 135
it should come out.
rossfingal
Thanks. I'm actually going to put the same window back in. I just need to remove it temporarily to bring in some 12' drywall.
Old 04-16-2013, 12:44 PM   #9
Ahhh!
12 ft. pieces of drywall in the basement!
That sounds like fun!
(Sorry, can't help - I'm busy!!)
rossfingal
Watch your "fire-blocking"!
Old 04-16-2013, 12:52 PM   #10
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Ahhh!
rossfingal
HaHa! Also, the drywall is 4.5 ft wide since I have 9 ft ceilings. Yes, the fireblocking is still confusing to me. I think I have it done except for the soffit right now. I'm planning a trip to see the inspector soon before I have him come out to ask him about it.
Old 04-16-2013, 01:06 PM   #11
Yeah, talk to the inspector.
Here's a link to "fire-blocking" in the "How-to guides" -
How to fireblock framing
rossfingal
The Following User Says Thank You to rossfingal For This Useful Post:
jonhayden (04-16-2013)
Old 04-16-2013, 05:50 PM   #12
Home Performance
HomeSealed's Avatar
Rewards Points: 712
4.5'x 12' , those are some big sheets. I know this is a really dumb question, but you've measured the clearance with the window out, right? I'm sure it is just the pic, but that looks like a tight fit.
www.HomeSealed.com
Old 04-16-2013, 06:00 PM   #13
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Window is 5' x 5'
Old 04-16-2013, 06:23 PM   #14
concretemasonry's Avatar
Rewards Points: 2,578
jon -
Despite the 5x5 window, the "wrinkled tin" well could inhibit the ability to get a long (12') x 4.5' sheet oriented and threaded down and turned around.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
HomeSealed (04-16-2013)
Old 04-16-2013, 06:26 PM   #15
What "jonhayden" means - the sheets aren't 4.5 ft. - the ceilings are 9 ft.
So - going to have either have a 1 ft. strip of drywall (if run horizontally)
Or run the sheets vertically.
"RF"
It's no fun! -
However, we've got sheets through a 5 ft. window well.
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 08:51 PM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
Slider window Rob461 General DIY Discussions 3 01-24-2011 11:40 AM
Removing window and patching stucco mark_anderson_u Remodeling 4 12-27-2010 12:04 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
