Removing Sash Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 01:07 AM   #1
Removing sash windows
Hi everyone, I was trying to take out a double hung sash window at an old house. The inner window had two screws on top of the sash that I removed. I did this and pulled the window out easily. As far as the outer sash, there are two pieces of metal on the underside of the sash that are held in with screws and these pieces of metal connect the bottom of the sash to a tab on the window's vertical track. The tab on the vertical track prevents the upper sash from being pulled out. However, even after removing the screws, the metal part that is connected to the tab on each side is stuck in the underside of the sash on both the left and the right sides. I tried pulling the window out and while the top comes out the bottom part doesn't budge. I can take a pliers and bend the metal part to remove it from the underside of sash but i'm afraid i'll break something. I need to take the window out and put it back in at a later time. Any thoughts?
mjo217 is offline   Reply With Quote
Old 07-06-2012, 11:32 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
Pictures are worth a thousand words in these cases.
Old 07-06-2012, 12:41 PM   #3
sash picture
this is the picture from the underside of the window. it's the metal piece with the hole in it(where the screw was) and i don't know how to remove it from window
Old 07-06-2012, 01:16 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
looks like a tilt pak to me
tilt in the top of the window,open 90 degrees tilt up one side of the sash and remove it
Tom Struble is offline   Reply With Quote
Old 07-06-2012, 01:20 PM   #5
what do you mean open 90 degrees?
Old 07-06-2012, 01:28 PM   #6
if i'm not mistaken your windows will tilt for cleaning?there may or may not be a latch, grab one corner of top of the sash and give it a pull while pushing in on the plastic jamb liner
if it does tilt open it 90degrees to the frame,then give it a twist,it should come right out
Old 07-06-2012, 03:09 PM   #7
the windows dont tilt for cleaning. they are older windows on an older house
Old 07-06-2012, 04:51 PM   #8
Rewards Points: 14,312
Sure looks like a pivit point at the bottom of the sash.
Lower the window and see if there's two latches at the top of the sash.
Old 07-06-2012, 05:30 PM   #9
your right, the windows are old but the sash?..not so much
they tilt
http://www.marvin.com/tilt_and_remove_tiltpac/
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (07-07-2012)
Old 07-08-2012, 01:04 PM   #10
so...hows this going?
Tags
double hung , sash , window
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
help figuring out windows Jeremy12 Windows and Doors 7 03-13-2012 03:04 PM
Front windows leaking dengle Windows and Doors 52 03-12-2012 10:54 AM
Can you flash replacement windows with existing siding? twobyfour2 Windows and Doors 3 05-31-2011 09:29 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
