Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-01-2012, 08:54 PM   #1
Removing Rimlocks
Hello. I am new to this website but figured someone may be able to answer this question for me. I have a home from the 1920s that has old rimlocks on the bedroom doors. These locks do not line up with their latches and the doors have been painted with so many layers they take some effort to close anyways. My goal is NOT to maintain this antique look and was wondering if there is a way to replace the rimlocks with new, modern doorknobs?
afulbrig is offline   Reply With Quote
Old 07-01-2012, 09:05 PM   #2
Removing Rimlocks
No clue what you mean by rim lock, post a picture.
Do they look like one of these? http://houseofantiquehardware.com/Do...-and-key-2-1-4
If the doors are that bad why not strip them and prime and repaint?
There's a few simple adjustments you can do to any door to get those old latches to line up again if there not that far off.
Old 07-01-2012, 09:17 PM   #3
Removing Rimlocks
They look like this -
http://houseofantiquehardware.com/re...-porcelain-set
I would like to strip the doors down as well but figured while I was at it if I could replace the old hardware as well.
The Following User Says Thank You to afulbrig For This Useful Post:
PaliBob (07-01-2012)
Old 07-01-2012, 09:40 PM   #4
Tool Geek
PaliBob's Avatar
Removing Rimlocks
brig, Thanks for the link. At the price of replacement Rimlocks
the upgrade to modern door knobs makes $ sense. The problem
is that when you remove the Old Rimlock you are left with that
gaping cavity.
You have two choices either just install new doors or use the
existing doors by strengthening or cutting in a new door section
around the old Rimlock.
& Stay Safe
.....Bob Lavery
Old 07-01-2012, 09:52 PM   #5
Removing Rimlocks
What's wrong with the old old ones other then they do not line up with the strike plates?
Old 07-01-2012, 10:03 PM   #6
Removing Rimlocks
The old locks are very difficult to turn and the mechanism is very loose. I attempted to tighten the screws but the inside of the lock appears to be mostly stripped. Besides these small issues, another reason for removal is for a more modern look as I change things.
I like the older homes because they are larger but I do not like some of the older things that are associated with them.
It appears that the lock is just screwed to the back of the door so I'm thinking I would just need to fill in the old screw and keyhole after redoing the door and then redo the frame around the door that has been cut into for the latch?
Old 07-01-2012, 10:37 PM   #7
Removing Rimlocks
Unless you post that picture it's had to say.
Old 07-01-2012, 10:44 PM   #8
Removing Rimlocks
I will post a picture when I return home tomorrow.
Old 07-02-2012, 02:47 AM   #9
Tool Geek
PaliBob's Avatar
Lightbulb
Removing Rimlocks
Hey brig,
To upgrade from mortise locks, the biggest problem is coping with that huge cavity created when the Rimlock (Mortise Lock) is removed. The biggest problem that I see is that other than filling the mortise cavity with wood, there is no connecting surface for the two Faceplate screws.
My first steps would be to first see whether or not a conversion kit could be installed.
They are cheap enough to try just buy one to see if it will work on your doors.
To convert to the newer tubular style door locks I would see whether or not a Mortise Lock Conversion Door Filler Plate would work for me. Note that on this plate the two holes to mount the Faceplate are threaded for the included screws. Again, I would start out buying just one to try it.
& Stay Safe
.....Bob Lavery
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 07:22 PM
removing tree roots from sewer tile 4just1don Plumbing 4 09-10-2010 08:23 PM
Removing Plastic Backsplash Tile ws450r Drywall & Plaster 5 07-12-2010 02:37 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
