Removing Old Door Knob/Fixture - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 01:07 PM   #1
I can't figure out how to remove door knobs from an old door knob fixture. Images of the knob/fixture can be seen in the URLS below.
http://imageshack.us/photo/my-images...802220451.jpg/
http://imageshack.us/photo/my-images...802220413.jpg/
http://imageshack.us/photo/my-images...802215326.jpg/
http://imageshack.us/photo/my-images...802215845.jpg/
From what I see there is no latch to engage to remove the knob. You will see a little hole in the shaft that connects to the knob with a little hole in it. I have tried putting a paper clip in it to see if it engages anything without luck.
Anyone have any experience with this kind of hardware or any thoughts?
mikeclancy is offline   Reply With Quote
Old 08-03-2012, 10:28 PM   #2
Rewards Points: 150
Looks to me like that set screw requires an allen (hex key) wrench, but someone stripped the corners out a bit.
NancyNGA is offline   Reply With Quote
Old 08-03-2012, 10:37 PM   #3
Rewards Points: 12,794
It's a set screw as suggest but be carefull it may be metric.
Make sure the wrench you use fits perfect. If not you'll just round it off.
Old 08-05-2012, 02:41 PM   #4
Thanks, ya'll hit it on the head. Can't believe I missed that. Was able to remove the knobs and other components after reading your replies. Thanks again.
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 07:22 PM
Removing Whirlpool double oven DSJ Electrical 1 02-06-2011 05:06 PM
Removing window and patching stucco mark_anderson_u Remodeling 4 12-27-2010 12:04 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
