Removing Metal Window Buck - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 10:11 PM   #1
Removing metal window buck
The metal buck in our basement window opening has rusted badly. Part of the buck metal has split due to rust. The buck was likely put when the basement walls were poured. How to take the meal buck out?
I am in Chicago area if anyone in trade is interested.
Would appreciate any suggestions.
vik
Removing metal window buck-bw_out2.jpg   Removing metal window buck-bw_out3.jpg   Removing metal window buck-bw_out4.jpg
Vk60564 is offline   Reply With Quote
Old 08-03-2013, 07:59 AM   #2
Rewards Points: 14,014
Got a picture, we can not see what your seeing without one.
Old 08-03-2013, 08:49 AM   #3
Just uploaded pictures. Thanks.
Old 08-03-2013, 10:27 AM   #4
MarginallyQualified
Rewards Points: 2,464
That "buck" looks more like galvanized sheet metal trim.
With implements of destruction and in reverse order of how it was installed.
Start with removing the window .
Old 08-03-2013, 11:24 AM   #5
Remove window, remove trim and casing, cut the frame in 1/2 in the middle and pry it out and replace.
A sawsall and a 4-1/2" grinder will do it.
Old 08-03-2013, 11:34 AM   #6
A few follow up questions:
1. Will prying work for the "fins" in the buck that are in the concrete? I am windering if it will take out big chunks of concrete.
2. What would you recommend replacing the metal buck with? Some kind of treated wood or composite?
Vik
Chicago area
Old 08-03-2013, 10:31 PM   #7
Too Short? Cut it Again!
Word is trickling back to me. I use folks up North in Winnetka but should have remembered Restoration Hardware. In looking their place in Naperville has closed I guess but I am told the place in Oak Brook is still open. Might be worth a chat with them about real window contractors in your area.
West suburban types worry me at times. Do you need me to draw you a map to show how to get from Naperville to Oak Brook?
I should have more recommendations soon.
Old 08-04-2013, 07:30 AM   #8
Bill Kearney
Rewards Points: 1,174
I'd lean toward getting a window professional to do it. Mainly because bending the metal to make a proper and decent looking flashing around it is a hassle unless you have a long enough metal bending brake.
wkearney99 is offline   Reply With Quote
Tags
window buck rusted.
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
Removing new construction window and installing a replacement! MikeVila Windows and Doors 12 10-20-2012 08:48 AM
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 12:06 PM
removing a window northeast Remodeling 3 07-24-2010 06:57 AM
removing 4x8 window smallcrpt Building & Construction 3 09-14-2009 11:46 PM
