Removed Window - Exterior Idea Help - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 10:00 AM   #1
Removed window - Exterior Idea help
I recently remodeled my bathroom and had to remove a window as the shower was installed in its location. I have old aluminum siding that is unavailable and was wondering about any good idea(s) on what to do with the outside where the window once was.
I have the area prepped, been insulated, framed in, plywood cut to fit hole, and vapor barrier. Now I am stuck with what to do with the exterior that is just sitting there exposed. Its too wide to fit a standard shutter (cut down for length). I'm just wondering if installing shutters of some sort to fit the opening would be the best idea/look from the outside or if there is another idea someone may have to fill it in to make it look decent.
icky1978 is offline   Reply With Quote
Old 07-29-2013, 10:06 AM   #2
kwikfishron's Avatar
Rewards Points: 996
Posting a picture of that side of the house would help.
kwikfishron is online now   Reply With Quote
Old 07-29-2013, 11:18 AM   #3
Will do. Thought of it at work.
Old 07-29-2013, 11:18 AM   #4
I agree, a picture would help.
Was thinking a simulated Vent, like ones Fypon sells, but don't know what all you are dealing with
hungryjack is offline   Reply With Quote
Old 08-01-2013, 09:14 AM   #5
Sorry a little late.
Old 08-01-2013, 10:24 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
That looks like a smooth 7" aluminum. It can be found, you'll probably only get it in white though and then you'll have to paint it. We have also bent new panels out of coil stock on occasion. Im not a big fan of scabbing in something to cover up where the window was like shutters or other decorative stuff.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 08-01-2013, 10:28 AM   #7
Rewards Points: 14,290
Is this picture posed side ways?
Where did you look for the siding?
Tried a real siding supply, not a box store?
If it was mine I think I would have resided that whole wall, anything else will look like poop and will leak with it's repaired like that.
Old 08-01-2013, 10:39 AM   #8
Yes sideways. My apologies. Its sealed good now. I get what you are saying about leaks if I were to side inside the opening. Ive contacted 2 non big box and had no luck. Havent looked into until now. Im in MI. Still searching for siding.
Old 08-01-2013, 11:32 AM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You have Richards Building supply in MI. Give them a shot.
ABC or Allied maybe viable as well.
www.HomeSealed.com
Old 08-01-2013, 01:40 PM   #10
I even saw some listed on the Menards web site if there's one near by.
Old 08-01-2013, 05:52 PM   #11
Davejss's Avatar
Rewards Points: 780
Order a storm window to fit the opening. Before installing it spray paint the interior glass with silver paint. Caulk and install. It will look exactly like a regular window.
Davejss is online now   Reply With Quote
Covering basement window mike-ss1 Building & Construction 6 03-26-2013 02:18 PM
uPVC window handle won't close window properly, how can I fix it? Epimenides Windows and Doors 4 02-10-2013 02:09 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
