Remove A Newly Installed Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-12-2014, 03:21 PM   #1
Rewards Points: 768
Remove a newly installed window
Yeah, so I installed 6 new windows along the west side of my house...it's an old house, nothing square, plumb, etc. After installing all 6, I sat back and admired my work only to noticed that one window on the first floor (3 first story, 3 directly above in second story) was 1" higher than the rest. ( I should add that I did have to build the opening up a bit since new windows were smaller than the openings). I don't know what happened and wished I had someone else to blame.
The windows are currently taped (window flashing), but I have not placed trim around the windows for siding.
Will I ruin the window if I pop the nails out of the fin remove flashing and the caulk from nailing flanges to take the window out of the opening or should I just live with my mistake?
cibula11 is offline   Reply With Quote
Old 05-12-2014, 04:58 PM   #2
Rewards Points: 1,284
A sawzall with a nail cutting blade is the normal tool to remove a window.
Saw the nails between the window frame and the sash opening, sat the window out, and re frame the opening to match the rest in height . Then re-install the window, after removing the sawn nail heads.
ED
de-nagorg is online now   Reply With Quote
Old 05-12-2014, 05:02 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,652
I'd fix it.
Just pop the flange nails carefully, cut and clean the caulk...no problem.
MTN REMODEL LLC is offline   Reply With Quote
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
cibula11 (05-12-2014), de-nagorg (05-12-2014)
Old 05-12-2014, 09:08 PM   #4
Rewards Points: 768
Will do...nothing like installing a window twice
Old 05-12-2014, 11:31 PM   #5
I did 4 wood. probably 4x6 ers with awning vents below, accross a living room wall.
Stood back and looked after install, and two were not lowE.
Supplier paid for all removal/replace costs.
Old 05-13-2014, 07:38 AM   #6
Don't look at it as a mistake, it is a lesson in
DO IT RIGHT THE FIRST TIME.
ED
Old 05-13-2014, 09:36 AM   #7
ED
AND always check each window to make sure it is or isn't low E.!
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
de-nagorg (05-13-2014)
Old 05-13-2014, 11:14 AM   #8
Rewards Points: 768
I was so concerned about the top and bottom windows being in line, I totally forgot about the height along the first floor.
That's also what I love about remodeling older homes....you can always say "It's 100yrs old, what do you expect" Most people never notice those things, but it drives me nuts.
Old 05-13-2014, 12:10 PM   #9
Really true... no one else will ever see it.... but for you it will be a glaring error that will shout at you every time you glance its way.... (I've got a couple of tiles like that... in 15 years, no one has never noticed, and they would give me krap if they ever did)
Old 05-13-2014, 12:51 PM   #10
It's been said numerous times that the "artiste" is their own worst critic.
They see the mistakes, where everyone else sees the beauty.
I know that I do that. So you are not alone in this particular mental boat.
After practice you can learn to IGNORE those little voices saying " It should be better".
ED
Slanted window - should I correct? miamicuse Windows and Doors 11 04-16-2013 07:59 AM
Just ripped out a newly installed floor because of a defect in tiles and need advice! mcu Flooring 21 03-01-2012 01:02 PM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 09:39 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
