Remove Individual Window To Install Venting - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-24-2014, 02:38 PM   #1
Remove individual window to install venting
So I am temporarily going to be operating our screen printing out of a location that I may or may not be in very long. So to not be so intrusive and to not put holes in the exterior walls I need to install some venting.
There is a window that is comprised of three separate pieces of glass. I would like to take the top on out and install a thick hardwood board with two 8 inch vent holes.
Now my problem is removing the window. Is this possible without damaging it?
tozier9 is offline   Reply With Quote
Old 01-24-2014, 03:43 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
if it operates you can just remove the sash,if not there may be screws in the sides that need to be removed,or a removable stop
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (01-25-2014)
Old 01-25-2014, 11:25 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Need to know more about the window, operation, and an interior shot.
Old 01-25-2014, 01:22 PM   #4
Registered User
Rewards Points: 526
Commercial or residential application? Any building codes or fire codes which might pertain; for your Insurance coverage..... what type of vents or are the windows inoperable?
Gary
Old 01-26-2014, 05:41 PM   #5
The window is inoperable and it is in a commercial space. It will have two 8 inch dampers.
Here are the updated pictures, I can't seem to find what is holding it together.
Old 02-01-2014, 07:09 PM   #6
Anyone have any thoughts?
Old 02-02-2014, 08:12 AM   #7
If you can do it without damaging them, the glazing bead can be removed and a piece swapped out as you indicated.
Not sure this is a first time DIY effort but it can be done.
Old 02-02-2014, 08:35 AM   #8
Here you go.
Old 02-02-2014, 11:05 AM   #9
Thanks everyone, I appreciate it.
So are you thinking I would use a razor blade to remove the silicon? On the outside is a large vinyl frame. Do you think if I removed the inside piece frame piece I could have someone on the inside catch the glass as I push the window gently from the outside?
Enjoy the Superbowl!
Old 02-04-2014, 04:14 PM   #10
Well I cracked the window trying to remove the glazing bead. Either way it has to be removed so...I had watched a youtube video on it but these wood pieces seem to be more difficult to remove. Is there silicon in there?
Old 02-05-2014, 10:39 AM   #11
Usually they are wet glazed (i.e. silicon).
This is where the pro and right tools is critical. You can get the glass remade so make sure it is taped up and you use proper PPE.
Old 02-05-2014, 10:40 AM   #12
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
Out of square window how best to install miamicuse Windows and Doors 5 04-19-2013 01:34 PM
Replacement window install question. joshg3p0 Windows and Doors 5 06-05-2012 10:32 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
