Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-23-2012, 05:40 PM   #1
remove fixed pane slider
How do I take the fixed pane out?? I have remove the trim pieces, just not sure what to do next. Does not appear there are any fasteners holding it in place. What do the experts think?
FYI_
allready lowered wheels, etc. Window will not lift out. Builders aluminum dual pane circa 1992.
sacseven is offline   Reply With Quote
Old 09-23-2012, 05:57 PM   #2
Framing Contractor
It is probably screwed in through the back side of the frame
sixeightten is online now   Reply With Quote
Old 09-23-2012, 06:00 PM   #3
chb70's Avatar
If it has the leveling wheels, you should be able to lift it out.
The older units did not have much clearance and you may need to pry the s*%t out of it.
Can You Dig It!
chb70 is offline   Reply With Quote
Old 09-23-2012, 06:05 PM   #4
chb70's Avatar
Just want to make sure, are you are able to move the pane side to side or is it still locked into place.
Can You Dig It!
Old 09-23-2012, 06:51 PM   #5
Fixed pane is still locked in to place. I can not find any screws where it attached to frame.
Do I want to focus on prying up first or from behind.
I am assuming that the sliding pane needs to have the fixed pane remove in order to be taken out.
Not sure if it has leveling wheels, I unscrewed the wheels completely and they are no long visible.
Old 09-23-2012, 07:44 PM   #6
Super Moderator
The moving door always gets removed first and installed last----
oh'mike is online now   Reply With Quote
Old 09-23-2012, 11:19 PM   #7
chb70's Avatar
If it is screwed through the back side of the frame, you would not be able to get to them. The frame side is against the wall, if that is the case then I would try to pry the frame away from the wall on the top and bottom, and try to break the screws from the frame.
Can You Dig It!
Tags
fixed pane, remove, sliding
Double or Triple Pane - worth it? hellothere123 Windows and Doors 13 02-19-2012 03:22 PM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
Anyone ever seen two windows not double pane? FixitDragon Windows and Doors 3 04-21-2011 05:58 PM
Soundproof Windows BlueJello General Discussion 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
